Digital I/O
write to digital can't work in labview7?
I had a vi used (write to digital.vi) and no error in labview 6.0(with PC-PIO-24).
But why it can't work in labview 7.0?
It said that the vi can't been found in llb.
And i could not found any vi like (write to digital port.vi) in labview7.
How to use this function in labview 7.0?
I just want to make the DIO card to output a digital patten like 01001000.
Can supply a example vi code with labview7 ?
Thanks!!!
(3,179 Views)
Hello:
LabVIEW 7.0 should have an example that will work for you. Launch the NI Example Finder by selecting "Help >> Find Examples." From there, navigate to the "Hardware Input and Output >> Traditional DAQ >> Digital Input and Output >> E-Series" and select the VI named "Write to 1 Dig Port.vi." This VI will do exactly what you want.
If you do not have those examples, then you need to reinstall NI-DAQ 7.1 (can be found on www.ni.com/support) and that should install those example files.
Good Luck!
Sincerely,
Brooks B
(3,179 Views)
