Digital Multimeters (DMMs) and Precision DC Sources
4070 - Waveforms and Resolution
Hi, how can I look up the resolution in digits on a waveform measurement? With the niDMM Configure Waveform Acquisition I can set up the rate. Is it just to read the table Digits -> Rate the other way around?
Thank you!
(2,960 Views)
Accepted by topic author PhilippPahlke
I believe you have to compute from this graph.
Santhosh
Soliton Technologies
(2,916 Views)
Thank you very much, sometimes it helps, to read the same document two days later again 😉
(2,905 Views)
