Digital Multimeters (DMMs) and Precision DC Sources
Continuous Mode VB6 example doesn't work on PCMCIA 4050
I tried to run the example for continuous measuring in my VB 6 IDE. The program runs fine, but won't return any value. All other example programs work.
Is it a known problem?
Best regards Christian
(7,613 Views)
Which example do you use exactly? If this example uses the "waveform mode" then it will not work with your hardware. You would need a 4070 for example to use the waveform-mode.
Could you post the example, or the source-code of the exampel you use?
André
(7,593 Views)
I used the "Cont Acq Multiple Samples" example from the Driver CD and tried to change the external trigger into a software trigger.
Do you find the Error in the Code?
-------8<---------------------------------------------
        'Open a session to the instrument
        If CheckError(niDMM_init(InstrDesc.Text, VI_TRUE, _
                VI_TRUE, VI)) Then GoTo Error
        'Configure the acquistion
        If CheckError(niDMM_ConfigureMeasurement(VI, CtlVal(measFunction), _
                    Val(Range.Text), Val(Resol.Text))) Then GoTo Error
        'Set the powerline frequency
        If CheckError(niDMM_ConfigurePowerLineFrequency(VI, _
                    CtlVal(PwrLineFreq))) Then GoTo Error
        'Set trigger source and delay
        If CheckError(niDMM_ConfigureTrigger(VI, NIDMM_VAL_IMMEDIATE, 0)) Then GoTo Error
        'Set trigger slope
        If CheckError(niDMM_ConfigureTriggerSlope(VI, triggerSlope)) Then GoTo Error
        Call niDMM_SendSoftwareTrigger(VI)
        'Set the number of measurements
        If CheckError(niDMM_ConfigureMultiPoint(VI, 1, NIDMM_VAL_SAMPLE_COUNT_INFINITE, NIDMM_VAL_IMMEDIATE, _
                    0#)) Then GoTo Error
        'Set sample trigger slope
        If CheckError(niDMM_ConfigureSampleTriggerSlope(VI, triggerSlope)) Then GoTo Error
        'Initiate the measurements
        If CheckError(niDMM_Initiate(VI)) Then GoTo Error
        'Turn on timer to check for available data from the DMM
        FetchTimer.Enabled = True
(7,582 Views)
To use a software-trigger you have to changes some things:
1.   If CheckError(niDMM_ConfigureTrigger(VI, NIDMM_VAL_IMMEDIATE, 0))  change to   If CheckError(niDMM_ConfigureTrigger(VI, NIDMM_VAL_SOFTWARE_TRIG, 0))
2. The line Call niDMM_SendSoftwareTrigger(VI) must be moved below the line  If CheckError(niDMM_Initiate(VI))
If all this does not help, you will have to do a little bit more debugging. What happens after the initiaalisation? Does the fetch - function returns invalid or no data, or does it return 0?
(7,572 Views)
