Digital Multimeters (DMMs) and Precision DC Sources
DMM plotting and data analysis
Hi, I am using DMM PXI 4071 to acquire DC measurement values by using niDMM Read Multi Point.
Now I want to find out the intersection between the graph of measured values to XY axis (Basically what I want to achieve is a function y=f(x) represented by this graph)
Greatly appreciated if anyone can give me a hint.
Thanks in advance
(6,860 Views)
Hi Dennis,
Just simply use Mathematics>>Fitting>>Linear Fit.vi.
An array of X should be a time of each point, and Y is an acquired data.
This function willl return you an intercept which is the point you wish to know.
REgards, Kate
(6,838 Views)
