Digital Multimeters (DMMs) and Precision DC Sources
Error -1074126845 occurred at niDMM Read Multi Point.vi
Hi all!
I've got a rather complicated application that instantiates some processes from a template in LabVIEW 7.1. All those processes need to access two NI-PCI4070 DMMs. The access in all processes is protected by semaphores. The devices are initalised and resetted within the main parental VI; the instrument handle ist stored in a Global where the processes can access 'em. Works fine as far as I can say.
BUT
whenever I abort one of the processes during debugging, I run into trouble.
1. When a DAQ process in the DMM was initaited and not yet finished, it will hang in all following calls until I stop LabVIEW. LV itself tries forever to stop that DAQ process. When I finally give up and abort LV, a BSOD appears due to locked pages. I understand this, but the driver call to NI-DMM should return after its timeout period has expired, should'nt it?
2. When there was no running DAQ process in the DMM, all following calls will create a timeout error:
'Error -1074126845 occurred at niDMM Read Multi Point.vi
Possible reason(s):
Driver Status: (Hex 0xBFFA2003) Primary Error: (Hex 0xBFFA2003) Max Time exceeded before operation completed.'
This must have to do with the NI-PXI 1010 chassis the DMMs reside in, as neither a restart of the VI or LabVIEW nor a reboot of the PC does fix this. In order to fix this I have to shut down the whole rig including the 1010 chassis and restart all.
The DMM part of the app is based on the example 'Acq & Graph Multiple Samples.vi'. I simply have placed the initialisation and shutdown part of this into another part of the app.
I tried to experiment with the example to force this error with no luck.
Any clues on how to fix this?
TIA and
Greetings from Germany!
Uwe
(7,673 Views)
Hi Uwe,
have you installed the newest version on the NI-DMM?
The "Error -1074126845" is probably due to a memory leak. If you are opening/closing several IVI session (with the niDMM Initialize.vi and niDMM Close.vi), try to open only one IVI session, do all your measurements and close the session when everything is done. Modify your application to create an IVI session only once at the beginning and close the session when everything is done, put the "Initialize" and "Close" VIs outside the loop (probably you have one).
Regards
Kai
(7,667 Views)
