Digital Multimeters (DMMs) and Precision DC Sources
Failure loading driver module
Hi all.when i try to initialise my DMM 4071 card,i am getting a error"failure loading criver module"..i am using DMM-2.7 and DMM4071 card.Wat may be the possible reason behind these.
(8,260 Views)
Hello
It's hard to say why the driver would fail to load without further debugging, as several things could cause this. A common reason for failure though is a bad installation. I would recommend trying to repair the driver, or even trying to upgrade to a newer version (NI-DMM 2.9 is the current one) if possible (i.e. your program does not require a now unsupported version of LabVIEW or some other reason). You can download it from ni.com.
Hope this fixes your issue, if not please post back.
Marcos
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(8,230 Views)
Hi Kirsch ,u r right..its because of the installation..i have downloaded the latest driver  and installed.When i rebooted it started working fine.Thanks a lot for that timely reply.
Hope u can help me  in these..
Kannappan
(8,226 Views)
