Digital Multimeters (DMMs) and Precision DC Sources
How do I use an NI4882 Task in VB.NET
I have a simple Visual Basic.NET form with a text box and an NI4882 Task. I have called the Run method for the NI4882 Task - Example: NI4881Task1.Run(). The Run method executes properly. How can I display the output of the Run method to the text box?
(7,819 Views)
I do not have VB.NET here, but if the output is in a displayable format you should be able to do textbox.text = somevalue
Hope this helps out.
Best Regards,
Aaron K.
Application Engineer
(7,819 Views)
I�m not sure exactly what NI-488.2 function you are using, but I�m currently using a wrapper around the GPIB-32 functions. In C#.Net, I have declared IBRD( ) to return a string called buffer. I can then display this string as AaronK discussed � textBox1.Text = buffer. If your return value isn�t a string, you can use the ToString( ) method as shown below:
// C#.net
int number = 1;
textBox1.Text = number.ToString();
Does this help? Good luck!
Nate D
(7,819 Views)
