Digital Multimeters (DMMs) and Precision DC Sources
How to send SCPI commands to a DMM with Labview?
How can I send SCPI commands (to use functions that I need and tehy are not included in the driver) to a Keithley Digital Multimeter?
(10,883 Views)
The LabVIEW <-> GPIB.vi example is a great place to get started. It will allow you to send and receive messages from an attached GPIB device directly, without the instrument driver. Using this as a base, you can produce your own VI('s) that can control your DMM. Also, check out our knowledgebase if you have specific quesitons at www.ni.com/support. There is a lot of information on generally getting GPIB up and running at www.ni.com/support/gpib as well.
Good luck, and let us know if you need more help.
Scott B.
Applications Engineering
(10,882 Views)
thx a lot, but it is possible to send these commands via Ethernet?
(10,883 Views)
