Digital Multimeters (DMMs) and Precision DC Sources
How to setup DMA in XP for PCI-6024
Problem; highest sample freq with Datalogging is for 8 channels 150Khz i.s.o. 200Khz for all channels.
Using;Dell Pc 2,8Ghz, Labview v6.i, NiDaq 6.9.2 and the HSDL vi's
(7,414 Views)
Hello;
You don't need to configure the DAQ device to perform DMA data transters. It's set as DMA by default.
The error you are getting can tell you more about the problem itself. I'm wondering if the problem is on the FIFO overflow which is caused by overhead in the while loop where the AI Read.vi is in. If that is the case, you will need to optimize the code inside the loop so you can retrieve data faster from the on board FIFO.
Hope this helps.
Filipe A.
(7,414 Views)
