Digital Multimeters (DMMs) and Precision DC Sources
I get an Error 2349 will not install IVI Shared Components?
I just purchased the PCI-4070 and can not install the NI-DMM Version 2.2 software. While installing It tells me it can not install IVI Shared components "Internal Error 2349". I am installing only the default options and nothing else. I have also tried downloading and installing IVI Compliance Package 2.1.1 and get the same error. After this error there are two more packages that will not install because they need the IVI Shared Components.
(7,155 Views)
The IVI Shared Components are not NI specific but are distributed by the IVI Foundation. This KnowledgeBase should help clarify a little bit.
http://digital.ni.com/public.nsf/websearch/5FAC92110A45875F86256D180057F075?OpenDocument
There is also a link to the IVI foundation website that has a clean-up utility that might help out.
Best Regards,
Jeremy R.
NI - Applications Engineer
(7,155 Views)
