Digital Multimeters (DMMs) and Precision DC Sources
Issue with PXIe-4139 OLP(overload pretection) Error
PXIe-4139 throws error 1074118575 which mentions that the device has activated Overload Protection (OLP).  To get it out of OLP, reset the device in NI MAX is needed. I was wondering if there is a stress test parameters on Reset Device in NI MAX. For example, how many times can I reset the SMU at most within a certain time (such as 10 seconds). Or maybe another solution to reslove the OLP issue? Thank you!
(4,519 Views)
This is the guide I have found most useful when dealing with OLP:
SMU Best Practices: Understanding Compliance and Device Protection Errors
Hope this helps!
(4,473 Views)
Thanks a lot!! I'll try following the steps on this link and see if it works in my situation.
Best Wishes!
(4,435 Views)
