Digital Multimeters (DMMs) and Precision DC Sources
Keithley 2000 reports "illegal command option"
When using one of the Keithley 2000 functions that were installed with the driver (I took the one "for GPIB only"; the other worked even worse), I perpetually get the same error on the DMM display: +961 (DCC Mode IDDCO error). I can't even initializise the instrument.
Using the generic GPIB element with LabVIEW works, so the connection and setup seems to be okay. However, I need deeper functions that the generic driver doesn't offer.
(7,787 Views)
i think to come along with your problem, i need a few more informations.
Can you communicate with the instrument (for example with Measurement&Automation Explorer)?
Do you have a better error code description?
I need version of: NI-VISA, LV, OS, Keithley2000 driver-version;
Hint: actual driver for Keithley 2000: Version 2.0
(7,786 Views)
Sorry, I lost the path to my question. The problem was the "language" of the Keithley: It was not set to SCPI.
(7,786 Views)
