Digital Multimeters (DMMs) and Precision DC Sources
Keithley 2001- can´t mult. read and trigger
Hello People from NI forum.
I am having some problems with my Labview/Keithley programs and after trying exhaustively, I come to you and maybe you can help me to find out what is going wrong.
1- my multi-read.VI from Labview/keithley´s driver doens´t work properly! It takes a lot´s of time to take the measure and doesnt return plausible values. Have you ever had this problem with this or not? if someone´s VI work well, please send me!!!!!
2- I can´t manage to make the trigger between these two devices!( switch keithley 7002 and multimeter keithley 2001) the single-measure.VI works reasonable good so, I change all the configuration for both programs, as related in the manual, but both program stops! It is like waiting each others answer. did someone have success with this communication?
3- I tryed to run some codes direct to the machine but I don´t know if is there some kind of order to send the informations to GPIB. I tryied some times and I could´t make the program wait using SQR either; It was really complicated to me. I dont know either wether I put the * TRIG command to take the trigger and continue running the program.
I used the programs given by Keithley and NI to try to run this; simply configuring and trying to run both programs together .
I would be really grateful if someone could help me with this!
regards
Leandro
ps- below, has the code that is sent to GPIB trough the programs, changed to make the trigger link:
(K7002)
*RST;*CLS;
:OPEN (@ 1!10,1!20);
:ARM:SOUR IMM;COUN 1;TCON:DIR ACC;
:ARM:LAY2:SOUR IMM;COUN INF;DEL 0.000000;
:ARM:LAY2:TCON:DIR ACC;
:TRIG:SOUR TLINK;COUN 9
;:TRIG:DEL 1.000000;TCON:PROT ASYN;ASYN:ILIN 1;OLIN 2;
:TRIG:TCON:DIR SOUR;
:SCAN (@ 1!10,1!20,1!30);
:INIT:CONT 0;CONT ON
(K2001)
:STAT:MEAS:EVEN?;
:ARM:COUN 1;SOUR IMM;TCON:DIR ACC;ASYN:ILIN 2;OLIN 1;
:ARM:LAY2:COUN 1;DEL 0.000000E+0;SOUR IMM;TIM 1.000000E+0;TCON:DIR ACC;ASYN:ILIN 2;OLIN 1;
:TRACE:FEED SENSE :TRACE:POIN 20 :TRIG:DEL 3;
:TRIG:COUN 1;DEL 0.000000E+0;SOUR IMM;TIM 1.000000E+0;TCON:DIR ACC;PROT ASYN;ASYN:ILIN 2;OLIN 1;
:STAT:MEAS:ENAB 32;
:*SRE 1
true? *TRG;/ false? (" ")
:*SRE 0;:DATA?
(6,716 Views)
Leandro,
Why don't you post this to the Keithley forum for Dmm's. I am sure someone there will help you.
By the way the US is celebrating Thanksgiving right now so don't expect an answer until Monday.
http://forum.keithley.com/phpBB3/index.php
(6,701 Views)
