Digital Multimeters (DMMs) and Precision DC Sources
Low-side connectors for the SA-413T
I have a series of PXIe-4139 SMUs with SA-413T for TRIAX for the HI-side, and screw terminals for the LO-side.  I'd like to change from screw terminals on the LO-side to cables.
I ordered my TRIAX cables through NI, but was unable to order a LO-side cable.  I've been unable to find a supplier or mechanical specification for the LO-side connectors on the SA-413T.  I believe that this connector is also used on other NI products, so I just need to find a name to purchase it.
Does anyone know how to get the LO-side connector that is used on the SA-413T?  I've attached a picture and it's the green connector that has screw terminals.
(2,165 Views)
If you look closely on the connector, the logo and engravings will help you identify the manufacturer and part number for that connector.
Santhosh
Soliton Technologies
(2,154 Views)
