Digital Multimeters (DMMs) and Precision DC Sources
Max 60hz notch filter only
MAX will only let me select the 60Hz notch filter on my virtual channels.
I use the 4351(PCI) temp and voltage logger with NI-DAQ 6.9. In the virtual channel properties sheet, I'm able to choose from 10,50, or 60Hz. If I select anything other than 60Hz, then reopen the properties sheet, it defaults back to 60. Any help would be appreciated. Thanks
(7,638 Views)
I have the same problem with this configuration:
Windows XP, MAX 2.2.0.3010, NI-Daq 6.9, LabView 6.1
and I still haven't found a solution but with a different configuration (Win ME,MAX 2.0.3.6, NI-DAQ 6.8, LabView 6.0) everithing works well! I'm still trying to understand where exactly the problem is.
(7,638 Views)
