Digital Multimeters (DMMs) and Precision DC Sources
Measure high level current with PXI 4070
Can I measure current up to 5 amps with PXI 4070 DMM card?
-TPJ
(8,832 Views)
How many times do you need to get the link to the specifications?
(8,823 Views)
TPJ,
One of my personal favorite support documents not directly linked from the product support page is the help file (also installed on your computer with the driver). While doing a search for "high current" I found a page entitled "High-Current (Up to 10 A) Measurement Considerations" (the path is NI Digital Multimeters Help » Devices » NI 4070 » DMM Measurements » DC and AC Current » High-Current...) that mentions we sell shunt resistors that will allow you to go beyond the DMM's maximum range. The NI CSM-10A current shunt should do the trick. I advise you to read the help file page for measurement considerations while using a current shunt.
I hope that helps!
Message Edited by Mark E on 11-07-2008 10:05 AM
Mark E.
Precision DC Product Support Engineer
(8,814 Views)
Thank you Mr. Mark for providing the information on high current measurements using current shunts.
Now I need a clarification. Since we shall be using an external NI CSM-10A current shunt, is there a need to recalibrate the PXI 4070 DMM card?
If YES, do we do the same in the Labview software?
-TPJ
(8,788 Views)
TPJ , If you need to recalibrate your card it can be easily done from measurement and automation explorer ( MAX) . This will be there once you have installed the drivers for your card . Please refer the image. You have an option of self calibrate her . You can also do an external calibration . Moreover we also provide feature of calibration in LabVIEW also . Hope this helps . Pranchal , NI India
(8,768 Views)
TPJ,
Any time you introduce variables that can alter your measurement (temperature, time, shunt resistors, etc.), I would recommend performing a self calibration in MAX, as pointed out by Pranchal. There is a shipping example within LabVIEW for DMMs as well as other devices. To access the shipping examples, select Help » Find Examples. Once inside the Example Finder, navigate to the DMM self calibration example using this path: Hardware Input and Output » Modular Instruments » NI-DMM (Digital Multimeters) » Advanced » SelfCal and Calibration Info.
I hope that helps!
Mark E.
(8,757 Views)
Thank you again Mr. Mark and Ms. Pranchal. I shall go through the examples available in Labview and get back to you for any further questions.
-TPJ
(8,742 Views)
