Digital Multimeters (DMMs) and Precision DC Sources
Measurement & Automation Explorer Window flickering
Morning!
While using the Measurement & Automation Explorer, I encountered a flickering window:
[Measurement & Automation Explorer -> Remote Systems -> cFP Bank -> (Right click on any item) Go to Items Configuration -> I/O Data (Tab)]
This phenomenon appeared after updating from Windows XP to Windows 7.
It seems as if Windows 7 refreshes the window all the time. Is there anything to do about it? It's quite annoying to work with... 😕
Thanks for any ideas! 🙂
Korbi
(6,970 Views)
Good Morning,
I have never encountered anything like this. You can try some things to address he problem:
Do you have the Problem on another Windows 7 Computer, too?
When exactly does this occur? The way I understood it is as follows: You try to configure an ethernet cFP via network, right?
So when you configure the IO Data, you get the flickering window.
Personally I've never worked with a cFP on Windows 7, so I haven't ecountered that problem, but I think that R&D would have fixed it already, if it was a common Problem.
Also do you have the newest Version of NI-RIO and FieldPoint?
RIO
Field Point
Additionally: What do you mean by Update to Windows 7?
Remember Cunningham's Law
(6,954 Views)
I am having the same problem after upgrading from WXP to W7 and from LV 2011 to LV2012.  Did you get any resolution for this problem? Thanks
(6,637 Views)
