Digital Multimeters (DMMs) and Precision DC Sources
NI 4060 INIT error
We have installed NI-DMM vs 2.5 on our Windows XP systems. I am unable to access
our PCI 4060 DMM using LabWindows CVI 8.0.1. (error -1074135031).  MAX vs 4.1 has the name
listed as "NI-4060 for PCI (device 1)"  but the CVI  "niDMM_init function" panel returns this error regardless
of resource name ("DAQ::1::INSTR" or "NI-4060"  etc).   The test panel in MAX works fine, but as a possibly related
problem the Soft Front Panel will not start and complains of missing application elements. Any ideas? Thanks
Bob
(6,964 Views)
Hi Bob,
What is the message that pops up with that error number? Screenshots would be best. Also, what kind of error (number and message) do you see with the soft front panel? Just to check, does the DMM throw the same error if you run one of the shipping examples, such as "Measure DC volts"? The most current version of NI-DMM is 2.6 - this may resolve the issue. I would recommend upgrading to that if it is an option.
Please post back with more questions and troubleshooting results, we want to make sure you get this fixed.
Andrew S.
National Instruments
(6,950 Views)
