Digital Multimeters (DMMs) and Precision DC Sources
NI DC Soft Front Panel, minorbug, minor bug with PXI-4110
Hi
The NI DC Soft Front Panel V14.0, with the PXI-4110, the negative voltage scroll, works as expected to -10V, but then rolls over to 0. If one changes in -1V steps, it goes.... -8, -9, -10, -1, -2 ..... instead of -8, -9, -10, -11, -12 ...
While at it, a simple thing I miss is a on/off button for all three voltages.
(Also, imo, it would be logical to get negative voltages with the down arrow, not up).
My 2C
(6,250 Views)
Accepted by topic author janaf
Hello Janaf,
I fully agree with both of your statements, I have filed a Correction Action Report which you can monitor in next releases of DCPower to see if this is fixed with the SFP. Number of CAR: 512257
I added notes that only manual insertion of numbers less than -10 works and that it was not logical to use increment arrow or up arrow to decrease the voltage output.
Best regards
JM, LabVIEW CLA
(6,219 Views)
