Digital Multimeters (DMMs) and Precision DC Sources
NI DMM Double Buffering
Hey,
I work with NI PXI3110 system,  DMM PXI4070
I want to measure a DC voltage waveform.
I want to know how can I leave the measurement running and get/ fetch the availble data from RAM at the same time.
Something like double buffering, measuring and reading data at the same time. When I have a certain number of samples, I want to fetch them.
The measuring process must go on. Something like an event structure for buffersize where i can fetch data when i have N samples available in the buffer/ ram. With the given NI DMM functions like "configure waveform" I must first define the number of waveform points, i can´t define positive infinity.
How can I realize that in a labview programm with the given opearation and proberty nodes.
thanks for posting ideas.
(5,876 Views)
Hey Benni,
Unfortunately, no, you cannot continuously stream waveform data from the PXI-4070.  See KB 333L7P2O for more information.
You can continuously acquire in DMM mode, as described in the KB.  In DMM mode, you can sample only up to 10kS/s, so if you need to sample faster than this, let us know the details on the signal you're sampling (voltage, required sample rate, etc) and we can provide other alternative modules.
-John Sullivan
Problem Solver
(5,864 Views)
