Digital Multimeters (DMMs) and Precision DC Sources
NI PXI-4070 with Labwindows/CVI p1
Hi
I just bought a DMM NI PXI-4070. Your latest driver is supported only by LabWindows/CVI 6.0. But, I'm using Labwindows/CVI 5.5p1. I'm woundering if your driver 1.6 can do the job (basic operations). If so, I will be able to use this device right now and it will let me some time to justified to my boss the upgrade.
Thank you
Alain Leclerc, ing.stag.
(6,731 Views)
NI-DMM 1.6 does not support the NI PXI-4070 so, no it will not work. However, the only thing in NI-DMM 2.0 that won't work with CVI 5.5p1 is the .uir files from the examples. The function panel works, and you can always call the functions directly without using the function panel.
(6,731 Views)
