Digital Multimeters (DMMs) and Precision DC Sources
PCI 4060DMM Non-repeatable Reading:
I am using PCI 4060 DMM with labWin/CVI6.0, TestStand 2.0 SW package. While doing the resistor value test, once in a while we will get "0" reading instead of right value, no error code "NAN" though. And such kind of problem is nonrepeatable. Has anyone ever experienced the similar problem before, not necessary to be same test instrument though?
(7,753 Views)
For NI's response, please refer to the email I sent you recently. Anybody else is welcome to give their input here though.
Best Regards,
Jeremy R.
NI - Applications Engineer
(7,751 Views)
I have same problem on my 4060 DMM board. Sometime, I get reading way out of range. I set the range to be 10, sometimes, I get -12.xxx. No error reported.
Please post solution on the forum to share. Thanks
My source code in Visaul Basic
r64Range = 10#
r64Resolution = 0.01
Status = -1
Emit ("Open a session....")
'mstrResource = "DAQ::" & Format$(miNIDeviceNumber, "0") & "::INSTR"
'Open a session to the instrument
iStatus = niDMM_init(mstrResource, VI_TRUE, VI_TRUE, miDeviceHandler)
If iStatus >= VI_SUCCESS Then
Call Writeln("OK.")
Emit ("Configure Resistance Measurement ....")
iStatus = niDMM_ConfigureMeasurement(miDeviceHandler, NIDMM_VAL_2_WIRE_RES, r64Range, r64Resolution)
If CheckError(iStatus) = VI_FALSE Then
Call Writeln("OK.")
Call Emit("Configure Multi Point....")
iStatus = niDMM_ConfigureMultiPoint(miDeviceHandler, TRIGGER_COUNT, SAMPLE_COUNT, NIDMM_VAL_IMMEDIATE, SAMPLE_INTERVAL_SECOND)
Call Writeln("OK.")
Call Writeln("Measure Resistance....")
'Read the measurements
iStatus = niDMM_ReadMultiPoint(miDeviceHandler, TIMEOUT_LIMINT_MILLI_SECOND, SAMPLE_COUNT, r64MeasArray(1), i32NumPointsRead)
If CheckError(iStatus) = VI_FALSE And i32NumPointsRead > 0 Then
'Status = 0
'Format and display measurements
iGoodSampleCount = 0
For i = 1 To i32NumPointsRead
If IsNumeric(Str$(r64MeasArray(i))) Then
If 0 < r64MeasArray(i) And r64MeasArray(i) < r64Range Then
'only sum up the goog data
dReading = dReading + r64MeasArray(i)
iGoodSampleCount = iGoodSampleCount + 1
End If
Writeln ("Readout " & Format$(r64MeasArray(i), "##0.000000 ") & vbCrLf)
Else
Status = -2
dReading = OVER_RANGE
Writeln ("Over Range" & vbCrLf)
Exit For
End If
Next i
If Status < 2 And (i32NumPointsRead - iGoodSampleCount) < BAD_SAMPLE_COUNT_MAX Then
Status = 0
dReading = dReading / iGoodSampleCount
Writeln ("Ave Read out " & Format$(dReading, "##0.000000") & " Ohms")
Else
Status = -1
Writeln ("Too many bad samples. No valid reading")
End If
Else
Writeln ("Failed")
RaiseEvent ErrorOccurred(PalletID, iStatus, "Failed to read the device", "ResistanceReadout", mstrParameterList)
End If
Else
Writeln ("Failed")
RaiseEvent ErrorOccurred(PalletID, iStatus, "Failed to configure the device", "ResistanceReadout", mstrParameterList)
End If
Else
Writeln ("Failed")
End If
Else
Call Writeln("Failed.")
RaiseEvent ErrorOccurred(PalletID, iStatus, "Failed to initialize the device", "ResistanceReadout", mstrParameterList)
End If
(7,533 Views)
Hey monkeytail123,
Please only post questions once. I have joined your thread located here to answer your question:
http://forums.ni.com/ni/board/message?board.id=80&message.id=393
-gaving
(7,509 Views)
