Digital Multimeters (DMMs) and Precision DC Sources
PXI 4071 Error_Query
How to use the Error_Query() in PXI 4071 to get the latest error?
int
error_query(System.IntPtr Instrument_Handle, out int Error_Code, System.Text.StringBuilder Error_Message);
Code snippet:
int
 r = IVIDMM_Fetch(10000, out rValue); //This stmt throws an error because initiate() is not called before Fetch()
int
errCode = 0;
string errMsg = "";
StringBuilder sb = new StringBuilder(errMsg);
IVIDMM_error_query(
ref errCode, ref errMsg); //This stmt does not get the error message/code of the previous error
What should be passed to the error_query() stmt to get the latest error message?
Priya.
(7,048 Views)
Hello Pirya,
Thanks for your post! I see that you are trying to get the error handling to work with your IVI DMM functions. I notice that you are missing the ViSession or Instrument Handle from your IVIDMM_error_query function. The instrument handle is information that you obtain from the IVIDMM_init or IVIDMM_initwithoptions functions. So at the moment there is nothing to identify a patricular session.
So even though there is no "init" called in your program the instrument handle r should be placed in the "error_querry" function.
IVIDMM_error_query(r, ref errCode, ref errMsg);
Adding the instrument handle should allow the function to associate its self with the session you have open.
Please post back if you have any further questions!
Cheers
Corby_B
http://www.ni.com/support
(7,017 Views)
Thanks for the reply! Actually i do have the handle and have called the init before this method call. Basically i am calling the .Net wrappers created by Measurement studio. This is the method i am calling:
public
int error_query(out int Error_Code, System.Text.StringBuilder Error_Message)
int pInvokeResult = PInvoke.error_query(this._handle, out Error_Code, Error_Message);
PInvoke.TestForError(this._handle, pInvokeResult);
return pInvokeResult;
The this._handle is already set. So i do have the handle but not able to get the error code and error message of the recent error 😞
StringBuilder
sb = new StringBuilder(errorMessage);
int status = DmmClassDriver.error_query(
out errorCode, sb); //calls the method given above...
Priya.
(7,003 Views)
