Digital Multimeters (DMMs) and Precision DC Sources
Query open Automation Refnums?
After using an activex automation open, is it possible to query for all open automation refnums?
I am attempting to create an error handler that will close any forgotten IVI sessions.
Is there perhaps a log file that contains all open references?
Chris
(8,578 Views)
Hello cjsesco:
Is there a reason that you are not closing each session after you are done. If you open and close a session everytime you want to perform a task, the program will be much slower due to the overhead in opening and closing.
Roland A.
Check out VI Roadshow
(8,553 Views)
When using numerous power supplies and assorted test equipment, by the end of a program there have been handfuls of sessions opened. Then considering that many of the programs based on user input will periodically close or open subsequent sessions. There is occasionally a forgotten session.
A session handler would be an easy alternative, as opposed to wasting hours reviewing someone else’s code.
Thank you for any help,
Chris
(8,542 Views)
Chris,
I am having the same problem.  Did you get an answer to your question?
-Ed
(8,437 Views)
Hi
I want to use automation open to remotely control the another instrument. I already connected to the refnum object but it's not working. Do i need to declare machine name?
(8,317 Views)
Hello Pocahontas:
Could you post a screen shot of the part of your code in question. Also, are you getting any LabVIEW errors?
Roland A.
(8,304 Views)
