Digital Multimeters (DMMs) and Precision DC Sources
Resistance measuring device
Hello Sir,
We want to measure the "Printed Circuit Board" connector pin resistance.
Below are the requirement.
  • Resistance measurement 0-1 Ohms.
  • Sampling rate of min 10 samples per sec per channel.
  • 132 channels
Please suggest a suitable cDAQ device that can measure the above said resistance.
(3,667 Views)
Sound like a end of line test.
Needed accuracy?
thougths on task:
The high pin or channel count target to a switched system ,
low impedance measurement to a 4 wire measurement
in conjunction with contacting* and TC voltages:  AC measurement or at least swapped polarity
*) the real hardware task (I think) for EOL test a pin-PCB impedance in 4 wire
max possible current  ?
suggested hardware:
switch martix (solid state?)
bipolar current source (or more switching), stable (traceable?) or one or more reference resistors
2 diff voltage channels
No cDAQ high channel switch matrix 😞
No cDAQ with a low ohm range (400Ohm )  😞
PXI-System with a SMU?
Greetings from Germany
Henrik
LV since v3.1
(3,604 Views)
