Digital Multimeters (DMMs) and Precision DC Sources
Run NI-DMM soft panel in simulation mode
Is it possible to run the NI-DMM soft panel in simulation mode (no hardware fitted)?
Regards
Ray Farmer
Regards
Ray Farmer
(8,951 Views)
No, the NI-DMM does not currently support simulation mode.
(8,951 Views)
It is not possible to use the NI-DMM soft front panel in simulation mode. It is, however, possible to write your own program (or use one of the provided examples) in simulation mode. The way to enable simulation is to use niDMM_InitWithOptions with an option string containing "simulate=1". You can also select which National Instruments DMM will be simulated by adding a DriverSetup clause to the option string. The format of DriverSetup is "DriverSetup=Model:AAA;Bus:BBB" where AAA is either 4050 or 4060 and BBB is PCMCIA for the NI 4050 and PCI or PXI for the NI 4060.
(8,951 Views)
