Digital Multimeters (DMMs) and Precision DC Sources
SMU PXIe-413x . Need example code for ramp up/down in C#
Does someone has a simple code in C# for ramping up/down a voltage/current for SMU 413x?
(2,796 Views)
You can use the Sequence mode example that ships with drivers.
Just pass in array of ramp values and associates delays between each value of the ramp signal.
Santhosh
Soliton Technologies
(2,762 Views)
To make your life easier, refer to this example
C:\Users\Public\Documents\National Instruments\NI-DCPower\Examples\DotNET 4.5\Sequence\Hardware-Timed Voltage Sweep\cs
There is a similar one for .NET 4.0 too (vb or cs)
Santhosh
(2,757 Views)
