Digital Multimeters (DMMs) and Precision DC Sources
Sequence time resolution for NI-4163
I am using the NI-4163 source measurement unit.   I want to generate a sequence of voltages using the python library nidcpower.   I am using the method set_sequence(values, source_delays)
The DCPower API documentation states the valid values for parameter "source_delays" is for 0 to 167 seconds.
What is the resolution?   The range is 0 - 167 seconds, what is the smallest valid time step for the NI-4163?
(283 Views)
The clock running that counter has a frequency of 180 MHz. This puts the resolution at 5.555556 ns
Marcos Kirsch
Chief Software Engineer
NI Driver Software
(190 Views)
