Digital Multimeters (DMMs) and Precision DC Sources
Synchronized measurement
Hi,  I am stucked with one problem. I need to synchronize two Agilent 34465A digital multimeters. I'm already trying to do this for a while time, but without success. The Multimeters has an Ext trigger that I would like to use. I need to get the devices into the wait for trigger mode, and then send a signal with the ext trigger to start measuring the values (synchonized).
Many thanks in advance for any suggestions.
(3,536 Views)
How do you connect these intruments to your PC?
(USB, Lan,GPIB?)
I didn't dive into the manuals (RTFM is your homework 😉 ) however how about calling a Keysight application engineer and ask if you can send one common trigger by the LAN ?
One crude way could be to (ab)use a RS232 (if present or by a USB adaptor) control line to send a trigger..  but often you have also some sort of a signal exiter source ...  or another sensor like mic/accelerometer/ contact ... ???
What are your timing requirements?
Greetings from Germany
Henrik
LV since v3.1
(3,508 Views)
