Digital Multimeters (DMMs) and Precision DC Sources
Use 2 PXI 4071 DMM
I have two PXI DMM 4071. With soft panel software is possible to measure with one DMM only.
Is possible download LabView code for DMM soft panel.
(7,145 Views)
Toni2,
While there is no way to download the LabVIEW source code for the DMM Soft Front Panel, there is a multitude of LabVIEW example programs which are installed with the NI-DMM software. (While in LabVIEW choose "Help -> Find Examples" from the menu bar.) These include applications which perform a large variety of DMM measurements. They may not have panels arranged in the same way as the DMM SFP (soft front panel), but they'll be your best resource for viewing data from more than one DMM at a time.
Thanks!
Alan L
(7,133 Views)
Toni2,
Having done some additional research here, I've found a workaround that you might find favorable. Essentially, just make a copy with a different name of the executable for the DMM Soft Front Panel (installed by default to the C:\Program Files\IVI\Drivers\niDmm directory). You'll then be able to use the SFP with more than one DMM.
Alan L
(7,125 Views)
