Digital Multimeters (DMMs) and Precision DC Sources
Vendors that build Combicon power supply cable assemblies
Does NI already have a vendor list that builds, or can build, power supply cables designed for the PXI-4110 (with "Combicon" connectors)?
(6,714 Views)
Hi broke-
     It turns out that we do not have a list of vendors that can do that specifically for the combicon connectors.  You may want to check with Phoenix Contact
     I hope this helps in some way.  Have a great day!
Gary P.
(6,708 Views)
I've tried that in the past and Phoenix was pretty unhelpful.  They did not manufacture cable assemblies with mini-combicon and could not suggest vendors.  I'll try them again...
I'm not sure how many PS modules with mini Combicon connectors that NI sells, but this seems like an opportunity for someone... perhaps one of your preferred vendors that integrates systems / builds fixturing.
(6,704 Views)
Thank you for the feedback!  I will be sure to relay this feedback to R&D.  Have a great day!
Gary P.
(6,691 Views)
Thank you Gary.  I appreciate it.
If I find a vendor that I'm happy with I'll be sure to feed the information back here for others as well.
Brian
(6,689 Views)
