Digital Multimeters (DMMs) and Precision DC Sources
Why do I need to call niDMM initiate inside the loop?
I'm trying to take DMM measurements continuoulsy.
By configuring the triggers to immediate and the sample and trigger count to 0 i would expect the DMM to start filling its buffer continuosly at its maximum rate, without ever getting back to the "idle state".
However, what I'm finding in practice is that I must call niDMM Initiate once again after taking each measurement.
Why is this occuring?
Does this mean that fetching the DMM will stop its multipoint acquisition process?
I attach two VI, one calling niDMM Initiate after each fetch and one which dont call it . From what I have understood i expected both to work, instead, only one of them do...
Could you give me some insight on the source of the different bahavior?
PS. I'm calling the trigger configuration because I will like to use an external trigger for the sample trigger in the future.
(6,737 Views)
DMM Initiate simply initiates acquisition, so it should not be used again in the loop.
I actually could not reproduce your issue (tough with a simulated DMM at the moment), both VIs run. What exactly do you mean saying that the VI without a second initiate doesn't work? Do you get some errors?
Try have a look at LabVIEW examples for DMM (in Example Finder, under Hardware Input and Output=> Modular Instruments=> DMM), in particular the ones for multipoint measurements and see if they work for you.
Bye!
Licia
(6,718 Views)
