Digital Multimeters (DMMs) and Precision DC Sources
dmm soft front panel command line parameters
Are there any command line parameters for the DMM soft front panel? I would like to set the measurement type and scale as the panel is launched.
(7,929 Views)
Unfortunately, the NI-DMM Soft Front Panel application does not support any command line options.
The NI-DMM development may consider this feature in some future release.
Are there any other NI-DMM Soft Front Panel options that you would like to see exposed, other than the stated measurement type and scale?
Sead Suskic
DMM Group
Regrads,
Sead Suskic
(7,929 Views)
I would also like to be tell the application the x, y, coordinate to postion itself on the screen as well a possibly the size that the window should be.
Thank you for your answer.
Tom Maiello
US Army ARDEC
Picatinny Arsenal, NJ
(7,929 Views)
Hello seed,
Is there any way in which I can set the null offset option in SFP programmatically. Waiting for your reply.
Ramesh
(7,175 Views)
