Digital Multimeters (DMMs) and Precision DC Sources
errors -10800 and -10401 with PXI-4060 after windows update KB905474.
I have a PXI 1033 system with 4022, 6229 and 4060 cards installed. Since the last windows update "KB905474" I get an error when trying to connect to the 4060 DMM. The other cards still work well. The orriginal error I got is -10800 "The device is not responding to the first IRQ level". I upgraded the NI-DMM software from 2.6 to 2.8 but this did not help. I put the 4060 in different slots, with the only result that I now get a different error: -10401 "The device did not pass the test". The windows update is automatic and cannot be uninstalled. What can I do?
(7,288 Views)
I found that the -10401 error dissapears after starting up the computer. Also I found that, although I get still the original error (-10800) when trying to run the testpanel in the Measurement & Automation program, I get no error when I start the DMM soft panel. I can hear the DMM 4060 click when I go to different measurement modes, but I still get no reading.
(7,285 Views)
I finally solved the problem by taking a different computer (not HP).
(7,190 Views)
