Digital Multimeters (DMMs) and Precision DC Sources
fast microsecond voltage source
I am currently using a Keithley 2410 Sourcemeter for my lab and I use it in my experiments as a voltage source for an RPA probe. I have written a VI for it that increases the voltage from say 0-500V at 5V increment. The speed at which it is increasing the voltage is set at its fastest at 0.01*NPLC, where NPLC = number of power line cycle, and 1*NPLC = 60Hz. The problems come when there are other "disturbances" in the circuit that causes the sourcemeter to slows down, such as from the plasma. This happens more often as I increase the voltage from another power supply that controls the plasma and every time it does, there seems to be a pause/hiccup from the sourcemeter. Are there any other power supplies or voltage sources that can provide a faster increase than 0.01*NPLC?
(7,709 Views)
Hi MaxXx-
     I have a couple of questions to clarify what you need.
1.  Do you absolutely need to go to 500V?  The highest we can source is 80 V by cascading our PXI-4110s.
2.  By 0.01*NPLC, do you mean 0.6 Hz (60 Hz*0.01)?  If you do mean 0.6 Hz, we should be able to easily beat that for speed of a voltage sweep.
     Let me know if 80V max is sufficient.  I am happy to help with any further questions you might have.
Gary P.
(7,693 Views)
MaxXx,
There is an application note on the Keithley web site on how to optimise the throughput of the sourcemeter:
http://www.keithley.com/data?asset=11641
The nplc has to do with the reading measurment time - do you need to measure or just source?
(7,682 Views)
National Instruments actually has an SMU that can source/sink 100V on a single channel.
http://www.ni.com/powersupplies/
Mark E.
Precision DC Product Support Engineer
(7,666 Views)
