Digital Multimeters (DMMs) and Precision DC Sources
how to measure very low current <1uA
Hello Everyone,
Does anyone knows how to measure a very lower current <1uA? What test equipment that able to carry out this kind of precise measurements?
-MJ
(8,541 Views)
Hey MJ,
1uA is low current, but we can certainly measure it.  Depending on what you're trying to do, the PXI-4071 and PXIe-4141 are great candidates.  Of course, if your application permits a large voltage drop (e.g. 10mV), you could use a large enough shunt resistor (e.g. 10kΩ) to convert 1uA to something a handheld DMM could measure... it all depends on your application.
Tell us more about your application and we can provide more specific guidance.
-John Sullivan
Problem Solver
(8,532 Views)
@Now_With_Underscores wrote:
Hey MJ,
I have used both the PXI-4071 DMM and the PXI-4141 SMU for such measurements. Both have pros and cons- just like any other engineering decision. The SMU solution turned out to be an elegant way to measure current with a zero effective voltage burden to the circuit.
PM me if you would like more details .
Jeff
Jeffrey Zola
(8,520 Views)
