Digital Multimeters (DMMs) and Precision DC Sources
i'm looking for Visual C++ example code or some kind of reference for aquiring waveform data using NI-4070 DMM
hello
i'm trying to find out how to aquire waveform data using an NI-4070. my application is in VC++.
so far i was unable to find examples for usage of waveform functions, or even a reference for these functions.
i'd appreciate any kind of help in finding such information.
thanks in advance,
Etz
(7,760 Views)
Hello Etz,
Refer to C:\Program Files\National Instruments\MeasurementStudio\VC\Examples\niDMM for examples of how to use your NI DMM in Visual C++.
A reference for the functions can be found in the NI-DMM Help file, found in Windows under the Start Menu at Programs >> National Instruments >> NI-DMM >> Documentation.  In the NI-DMM Help File, navigate in the Contents on the left to NI Digital Multimeters Help >> Programming with NI-DMM >> NI-DMM C/CVI/VB Reference Help.
I hope this helps.  Let me know if you have any questions!
(7,751 Views)
your can start the Visual C++ in "Console application" and then select "simple application".
Now go to C:\prog.. files\Nationa.... \NIDAQ\Examples\ANSI C examples
select one of example with  c extention and open with notepad than select all and copy then paste it to
VC environment
will work fine
enjoy
Haider
(7,517 Views)
