Digital Multimeters (DMMs) and Precision DC Sources
ni 9263 digital or analog output?
Hi all,
i'm kinda lost with all those forums I hope i'm in the right one.
I've looked into NI-9263 data sheet:
http://www.ni.com/datasheet/pdf/en/ds-59
the datasheet sais it have analog output (which doesnt make sense to me, if u have DC input to the module).
then the datasheet state it has 100 kS/s "analog" output.
so does it have analog or digital output?
is that output is actually PWM with 100 kHz frequency?
Thanks alot,
moran.
(4,341 Views)
It is an analog output.  I'm not sure where you are seeing the DC input.  The only place power is coming into the module is throught the backplane connector.  And the maximum sample rate for the analog outputs is 100 kS/sec/channel.
If you are trying to make a PWM, you might want to think about using a digital output module like the 9401.
(4,328 Views)
