Digital Multimeters (DMMs) and Precision DC Sources
power supply
Does NI have a power supply with the following specs?
Input: 1 phase, 230V+/-10% AC, 50% +/-5% Hz
Output:
a. 110V DC, 10 A continuous
b. 220V DC, 10A continuous
(6,527 Views)
(6,515 Views)
None of the power supplies mentioned here go beyond 100V. I was looking for a HV power supply which can go upto 220V.
(6,488 Views)
Please contact NI Regional Sales in your region.
Sahil Singla
Applications Engineer | National Instruments
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved)
(6,473 Views)
Hello Avanch,
Unfortunately, NI does not sell power supplies that can deliver the power you're looking for at the Voltage and Current levels you require.  While it is theoretically possible to gang numerous NI power supplies together with external circuitry to achieve the output you're looking for, this would not be practical (it would, however, be very accurate ;).
I recommend using a programmable external power supply, such as a Lambda GEN 300-11.  They even have an optional GPIB interface and an excellent Driver that works in LabVIEW.  I've personally used their instrument driver for a couple years now to charge an electric vehicle and promise you it is brilliantly simple.  Don't have GPIB?  NI sells USB/PCI/PXI to GPIB converters!
Couple this with LabVIEW and you've got an automated, programmable power supply, ready to pump up the Watts!
John S.
Precision DC Hardware Engineer
(6,456 Views)
