Digital Multimeters (DMMs) and Precision DC Sources
pxi 4060 backplane connection
I have PXI-1000B chassis, 2503 MUX and 4060 DMM. I have to scan 12 or so inputs and for now I am using CB-68LP terminal block. Is there any chance to use PXI chassis� back plane to connect to MUX and DMM instead of using front panel. As a result this would eliminate two wires going to the terminal block.
(8,176 Views)
No, the only signals between the NI-4060 and NI-2503 that you are able to share along the PXI backplane are trigger signals. The NI-2503 can only route the common of its MUX to the terminal block and the analog inputs for the NI-4060 are only available on the front panel through the banana plugs.
Hope this helps.
Jack A.
(8,175 Views)
Just how do you share trigger signals between the 2503 and the 4060? I have looked at the
documentation and examples and still can not find information on the capabilites and
configuration to do this.
Ernest
(7,823 Views)
Hi Ernest,
Here is a good document on how all of this is done (it's called handshaking, and the switch and DMM send triggers to each other when each one is done doing its job):
http://zone.ni.com/devzone/conceptd.nsf/webmain/6daaebb0952e54b386256e3700808423
I know it's a lot of reading, but it could be useful for your application.
There is then a good example of this in the example finder using the NI-SWITCH API:
Help >> Find Examples.. >> Hardware Input and Output >> Modular Instruments >> NI-SWITCH >> niSwitch DMM Switch Handshaking.vi
With the information above and this example, you should be well on your way to getting these two devices to work well with each other.
mike
(7,809 Views)
