Digital Multimeters (DMMs) and Precision DC Sources
pxi-4070
I have been trying to measure the voltage of the PWM signal shown on a PXI-4070 DMM with no success.  I keep getting NaN (overange)
I tried measuring on the DMM soft front panel but I get the same thing , overange
I think the waveform is within the DMM limits for freq and voltage
Any ideas ?
Thanks, Ross
(4,238 Views)
What are your DMM settings? Have you tried digitizer mode to see if you are measuring everything you expect?
(4,216 Views)
Im not familiar with digitizer mode.  Would you please point to documentation for 4070 digitizer mode
Thanks, Ross
(4,173 Views)
Accepted by topic author roscoe1088
If you are using LabVIEW there are also a couple examples to help get you started:
(4,169 Views)
