Discovering and Imaging the Device
Imaging Roborio gives error, Corrupt Firmware Cannot Run
CorruptRoborio.jpgImaging the roborio causes this issue. I have followed every step in this guide and asked people on discord with no luck. Trying to put new firmware on the roborio also gives an error. I believe I need a new USB image.
(3,307 Views)
Seeing as so many of us have this problem https://forums.ni.com/t5/Discovering-and-Imaging-the/Cannot-image-roboRIO/td-p/4150312 you'd think NI would make this an easier issue to fix.  Here's to hoping we get help soon.
(3,265 Views)
Hi KSpooky,
Just to confirm, are you able to get the roborio into safemode? If so, can you try to re-image it then?
(the reason we try the USB method as an absolute last resort is if it fails, there is no option but to RMA the roboRIO).
(3,243 Views)
The roborio was in safe mode when I tried the steps above.
(3,237 Views)
I sent you the recovery file and instructions (in a DM and using the email in your profile). Please let post back whether or not that works for you.
(3,235 Views)
