Discovering and Imaging the Device
Robo Rio2 not Imaging Fix
I struggled for hours trying to image the Rio2. The image is already there, on the SD card. All you need to do is change your team name-select edit startup settings-apply  and wait. It is done.
(1,584 Views)
What image did your roboRIO 2.0 come with? I suspect it isn't the final release.
From: https://docs.wpilib.org/en/latest/docs/zero-to-robot/step-3/imaging-your-roborio.html
The first time a roboRIO 2 is imaged (or if the microSD card is replaced with a new card), it must be imaged using roboRIO 2.0 microSD card imaging process.
(1,550 Views)
I used a downloaded image, ran through raspberry pi imager to the SD card. Don't overthink it. burn the image to the card, make sure your number is set and you are done, you do not need to burn the image to the Rio, it is already on the SD card
(1,544 Views)
