Discovering and Imaging the Device
RoboRIO 1.0 not imaging (unrecoverable error)
Hi there!
We are attempting to reimage an old roboRIO, however, when we attempt this, the status LED begins blinking continuously and we receive the error message attached below. We have tried putting the roboRIO in safe mode, as well as resetting the rio with a recovery file as described here, however, in both cases the result has been the same.
Is there a way to fix this issue? Thanks!
(2,110 Views)
Have you tried a few different flash drives for the recovery process?
(2,084 Views)
Hi crossmanm, I'm Matthew with NI.
As sciencewhiz suggested, can you try some other flash drives? older ones (non usb-3) tend to work better.
(2,073 Views)
Hi, having the same issue.   Any way I could get the recovery.cfg file to try?
(1,986 Views)
Hi Saberbotics,
To reset the a roboRIO to factory image following the steps documented here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000kOHkCAM&l=en-US (this links the file you're asking about).
If you don't find success, please post your own thread with details of what you've tried. (this helps us keep track of which teams have tried which steps)
(1,983 Views)
