Discovering and Imaging the Device
imaging roborio 2
Our roborio 2 has a continuous flashing light. What we understand it is an indication of an unrecoverable error
Here is the process we have completed:
1) We flashed the SD card using raspberry pi option
2) We put the SD card back in the Roborio and we have a continuous flashing light
3) We attempted imaging the Roborio and it does not find the roborio
Troubleshooting:
Tried reset button
It is connected to the laptop by ethernet-usb
(3,092 Views)
continous flash is an error state 😞
Can you try:
shut down the roboRIO
re-image the card
re-insert
power the roboRIO
If it enters error state again, maybe try imaging the card with one of the other options? - https://docs.wpilib.org/en/stable/docs/software/roborio-info/roborio2-imaging.html#writing-the-image...
(3,052 Views)
What is the name of the file you flashed to the SD Card?
(3,033 Views)
FRC_RoboRio2_2022_V3.0.zip
(3,006 Views)
That's not the correct image file name for SD card imaging. It should be .img.zip
(3,003 Views)
