Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
3D parametric graph
I would like to reuse a VI I once wrote under Labview 2010 which is based on the 3D parametric graph (activeX). I am now developing under Labview 2012 and it seems this activeX object has disappeared... is there a way to make the VI runs under Labview 2012? If not is there an equivalent function that would not require much modifications to the VI?
Sébastien
0 kudos
Mensaje 1 de 2
3.128 Vistas
Well in fact I noticed that this ActiveX object is still present in Labview 2012 but the control can not be loaded. The OS of this machine is Windows 7 64-bit professional. I found a section of the Labview documentation where it is stated that .net framework above or equal to 2.0 should be installed... this is the case as .net 3.5.1 is installed (by default on Windows 7). Any idea?
Best,
Sébastien
0 kudos
Mensaje 2 de 2
3.127 Vistas
