Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Adquisition and inspection with 2 gige cameras Basler in Vision Builder 2010
I am in course of making an application with 2 cameras basler scA1000-30gm in Vision Builder 2010 with ni DAQmx.
I have seen the example solutions for the multiple camera adq. and i have made a program in VB2010 in order to adquire the 2 images and inspect them.
My issue is with the point of Timeout Error of the Image Adq. Step. i observe sometimes one of the two cameras is in Timeout Error so the process is not being completed.
I have put 5000 for the Timeout.
I also observe sometimes i have double trigger. Why that happens? If i am sending for every trigger one pulse of 10 miliseconds?
Someone could resolve my questions?
I am new in the area, so i am learning all that stuff, and i am excited about the results.
Well, just to resolve these issues.
I can send my program if that needed, also more info about the application.
Thank you in advance,
Ioannis.
0 kudos
Mensaje 1 de 3
3.400 Vistas
Hi tzatz
I recommend you to post in the english forum and even more in the Vision part of the english forum, because currently your post is in the spanish forum and that is probably the reason because nobody has answered your question, Here i leave you the link to the forum where you have to post http://forums.ni.com/t5/Machine-Vision/bd-p/200
cheers.
Felipe RC
Field Applications Engineer
National Instruments para Chile, Argentina, Perú, Bolivia, Paraguay y Uruguay
(Si mi respuesta te ayudo dale click a la estrella para el Kudos)
0 kudos
Mensaje 2 de 3
3.298 Vistas
Thank you for the observation:)
0 kudos
Mensaje 3 de 3
3.273 Vistas
