Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Goepel PXI3072 - LIN - Example Code
Is there example code for managing with Labview the LIN communications with the Goepel card PXI3072?
I've bought the card to Goepel (it's indicated on the NI web) but I've only one sample and the manual guide, I'm searching on the forums but I don't find additional support.
If someone can help me ...
0 kudos
Mensaje 1 de 4
4.481 Vistas
Hi ihb, for additional examples you should contact Goepel, also you pasted the forum on the Spanish community, you will have more replies in this topic if you paste it in LabVIEW forum
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
0 kudos
Mensaje 2 de 4
4.471 Vistas
I put in the spanish forum because I made a mistake (It was my introduction to the NI Forum).
0 kudos
Mensaje 3 de 4
4.361 Vistas
Hi, IHB i didnt wanted to be rude, sorry about that and welcome to the forums.
You are always welcome to make post heres, just as been in english they will have fewer posts.
Thanks for using the forum and again welcome to the comunity
Best Regards
Benjamin C
Mensaje 4 de 4
4.353 Vistas
