06-17-2011 09:18 AM - editado 06-17-2011 09:19 AM
Hi flote,
I'm curious, when you downloaded and installed the new patch did you also update your project to include the new CLIP? Please notice that the updated CLIP is version 1.1.0, I believe the one before the patch is 1.0.0.
Kyle S
el 06-17-2011 11:56 AM
Yes It's the version 1.1.0. And the results are the same. Error in the map.exe and following fail the instalation. I dont know what's is happening. Have you tried to compile your program with the LowSpeed CLIP and is it works??? 😞
PD: Of course, I have the SP1 of LAbView 2010 installed...
Thanks a lot anyway!
el 06-18-2011 03:08 PM
A LabView Enginier has solved my problem. Here is the solution:
reinstall the driver
NI FlexRIO Adapter Module Support 2.1.2
http://joule.ni.com/nidu/cds/view/p/id/2399/lang/de
Install the patch
Error, “Compilation failed due to a Xilinx error,” When Using NI FlexRIO
http://digital.ni.com/public.nsf/allkb/BBD7A87F2ADC2028862577FB005F6B19?OpenDocument
Please follow the instructions in the patch
carefully check after restart that the variable
in the system is created
Check if the CLIP version to 1.1.0 is selected.
Stat compiling the files.
Install the patch
el 06-20-2011 09:09 AM
Hi flote,
That is great to here we got passed the compilation error! Is everything working and the FlexRIO operating in the proper Low Speed Mode? I am working on making this information more accessible for future users and want to double check that you have everything up and running.
Kyle S
el 06-20-2011 09:18 AM
Hi KyleTTU,
Yes the CLIP is working properly in the LowSpeed Mode. So now I can choose a lower sample clock!
Thank you for everthing!
