Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
MaxTerminatedServiceError
Hi, I'm having problems with Max corrupted database (MaxTerminatedServiceError), I've already tried, the option, tools=> Reset configuration Data, I've tried deleting the data files manually, restore backup on Data folder, repair Max 5.0, Labview files published on forums to fix this problem, and the problem is still there, windows does not see two of my NI cards, and Max only see two of them but with no Serial number, and does not pass self test.
What else can I do??
Thank you for your help!
0 kudos
Mensaje 1 de 4
4.859 Vistas
Hey there!!
You may need to stop and restart some services that MAX has access to..
Here is a link that may help you
Greetings
0 kudos
Mensaje 2 de 4
4.843 Vistas
The problem was solved, I reinstalled all drivers from mother board.
0 kudos
Mensaje 3 de 4
4.838 Vistas
Hi C_Almaguer,
Glad to hear that!
0 kudos
Mensaje 4 de 4
4.834 Vistas
